Summary: This thread discusses whether and how Zabbix can be integrated with Dynatrace. It explains possible connection points, what can be exchanged, and current limitations around direct integrations.
How can we integrate Zabbix with Dynatrace? I have both tools, but don´t want to have to use the 2 Agents.
Hello @Toshiba_ ,
we as a Dynatrace and Zabbix partner have developed an advanced integration of Zabbix into Dynatrace. It’s now just in the process of being available in the Dynatrace HUB, but we can show you the demo or a trial version anytime.
Julius
Hello @Toshiba_ ,
the extension is already in the HUB - https://www.dynatrace.com/hub/detail/zabbix-integration/ , there you can also find the link to the documentation and description of features.
Julius
