Integration with BMC event management
Dear All,
How to integrate Dynatrace Managed with BMC event management?
Babar
According to documentation, webhook should be way to do that:
https://docs.bmc.com/docs/display/public/tsim105/Creating+events+with+web+services
Hello @sebastian k.
We want to integrate through a script, as the customer has only this option available at the moment. Later on, they will move to the BMC TrueSight so we can use the WebHook.
Do we have a way to use any generic plugin for this purpose like we are using in the AppMon?
Babar
There is no such thing. Only Idea I have is kid of cron script that will be executed every minute (or more often if you need) and will collect problems via DT API and then push them to BMC. But you will have to develop this kind of script.
Hello @sebastian k.
What can be the expected impact on ActiveGate/Cluster performance, in case we follow the path as a workaround?
Babar
Shouldn’t be any.
Hello @sebastian k.
Is the SNMP trap supported by Dynatrace Managed to ship the anomalies to third party tools?
Babar
To make sure that there will be no impact, please take a look ahead at What is API monitoring?. If you follow the bets practices you will be fine.
Btw it would never make sense to query the API more often than every minute, as the minimum display resolution is anyway one minute.
Regards
Silvia
Take a look at about the SNMP trap: https://community.dynatrace.com/spaces/482/dynatrace-open-qa/questions/202654/can-we-send-snmp-traps-from-dynatrace-managed-clus.html
Hello @Silvia M.
Getting the following message on the access of URLs inside the shared link.
Babar
GitHub - Dynatrace-Reinhard-Pilz/snmptrap · GitHub I think this one should work.
Cheers
Silvia
Hello Babar_Qayyum, we have BMC TrueSight Infrastructure Management 11.3.04. Is it possible to connect Dynatrace Managed with Webhook to the BMC TrueSight event console? Our problem is what to do on the BMC side to make this work.
Which profiles/roles are necessary?
Do we need to integrate an additional application for the REST API?
in Dynatrace we have defined a Custom Integration with Authorization in Base64-encoded format and Content Type application/json
can you help us here?
We get the error message
Custom Integration test failed
Reason: Invalid HTTP status code
HTTP Response Code: 401 - Unauthorized
Annette
Hello @annette_gaschle
Please verify the proper authorization?
Babar
Hello Babar_Qayyum, the call to the URL directs me to BMC TSOM RSSO. When I enter my user ID and password I get
Error Code : 404
Regards, Annette
