Send Problem Event to BitBucket or Bambooo
Hi, how can I send Dynatrace to BitBucket?
The aim is the to have a Bamboo build triggered when there is a low disk problem on Dynatrace. I have tried sending an alert to Bamboo but it was not working (using workflow). Now I want the alert to be sent to BitBucket Repo since it is linked to Bamboo.
Hi
Use the Webhook integration for this: https://www.dynatrace.com/integrations/webhooks/
Radek
Hi, I get the below error when using the Webhook integration. Please note that we are using Saas environment and this error does not appear when I try it on a managed Dynatrace environment.
Hi @Itani_ML
Have you managed to solve the problem? It would be great if you shared the solution with the Community users :light_bulb:
