Integration with the Aranda management tool
[Edit from moderator with translation from Google:
Within the scope of the Dynatrace implementation, integration with the Aranda management tool is planned. In this context, I would appreciate your assistance in providing us with information on the necessary requirements for carrying out this integration, both technically and functionally.
Thank you very much for your cooperation.]
Dentro del alcance de la implementación de Dynatrace , se contempla la integración con la herramienta de gestión Aranda . En este contexto, agradezco su colaboración indicándonos la información sobre los requisitos necesarios para llevar a cabo dicha integración, tanto a nivel técnico como funcional.
Muchas gracias por su colaboración.
Is Aranda a ITSM?
Best regards
SI,
Dynatrace does not have a officitial connector for that, then, you can use Send Dynatrace notifications via webhooks.
Maybe this blog is useful also.
Best regards
