Hi all, I have created a browser clickpath synthetic monitoring to monitor the website https://www.kpwkm.gov.my I have set two locations to test the website, consists of N.Virginia and Sydney. It will send synthetic request with an interval of 15 minutes.
As a result, I am seeing intermittent connection timeout to the website. The issue is only occuring at the location N.Virginia. However, when I tried to VPN from the United States servers, the website seems to load succesfully.
Anyone, can anyone guide me to troubleshooot the connection timeout issue?
@Konrad_Lisiecki answered this question in a different place. Please find out a copy of it below.
"You can modify requests and connect timeouts used by your particular synthetic-enabled AG. This can be achieved by adding/modifying custom configuration files as below. Thereâs however no possibility to overwrite settings per particular monitor.
Of course this applies if weâre talking about private synthetic monitoring.
Itâs not completely clear if the Topic Starter uses private or public endpoints, but by the names used I think these are public (AWS) locations.
Under settings of the application specific Performance thresholds can be set.
Great solution Agata. I wanted to help everyone a bit more regarding mass update using Monaco.
We had the same original problem in our organization but we had roughly 500 synthetics it impacted. So, using Monaco we managed to adjust everything to 60 seconds (from 10 seconds) in seconds.
