I want to monitor a slow page (response time >10s) with synthetic monitor in Dynatrace managed, but the request times out after 10s (Request timeout to xxxxxxxxxxxxxxxxxxx/192.168.122.100:443 after 10000 ms).
Is it possible to overwrite this timeout for this peculiar monitor ?
@Jean-Pierre R. provided we’re talking about private synthetic monitoring and depending on which monitor type you’re referring to (wasn’t specified in question), you can modify requests and connect timeouts used by your particular synthetic-enabled AG. This can be achieved by adding/modifying custom configuration files as below. There’s however no possibility to overwrite settings per particular monitor.
We have HTTP/HTTPS synthetic tests for which our company is ok with up to 120 second response times but this metric is causing a bunch of false alerts. Yes, we increased it to 60 to take care of most issues but we need it to go higher.
It doesn’t seem to work when we are configuring this in a private synthetic location.
Also tried to find the same param in official docs but couldn’t find it anywhere.
Can you confirm if this is something that is still applicable and can be configured?
