HTTP Monitor default timeout value
I’ve looked in the documentation but I was unable to find this kind of information: does someone know which is the default timeout value for HTTP Monitor requests?
Thanks!
Roberto
I believe it’s 10 seconds.
Hi Roberto,
The default connect timeout is set to 5 seconds.
The default socket/read timeout is set to 10 seconds.
We’re working on making it configurable per monitor.
Tomek
This can now be configured per request using the ‘Adapt request timeout’ option. Configure HTTP monitors in Classic — Dynatrace Docs
Thanks for sharing this. Helpful.
Alex Romanenkov
How do we actually apply this setting?  The documentation mentions there is an adapt request timeout, but I can’t find anywhere that shows how to apply this setting.
I imagine it goes into the pre-request script, but I can’t find what the actual property name is.  The Browser monitor script page doesn’t have the word timeout anywhere in it.  I did find mention in the terraform docs for the Dynatrace provider, but I don’t know if the property name they use is the exact same as the property name that the script uses, nor do I know where to put it.
By default, it’s in the request object, requestTimeout. However, it’s only required if you want to change from the default value.
"requests": [
        "description": "ABC",
        "url": "https://xxx",
        "method": "GET",
        "validation": {
          "rules": [
              "type": "httpStatusesList",
              "value": "<400",
              "passIfFound": true
        "configuration": {
          "acceptAnyCertificate": true,
          "followRedirects": true,
          "shouldNotPersistSensitiveData": false
        "requestTimeout": 59
This value is ignored if you’re part of the HTTP Monitor Advanced settings preview.
For the preview, requestTimeout, should be removed from the script, and instead, a customProperties added.
"requests": [
        "method": "GET",
        "validation": {
          "rules": [
              "value": "<400",
              "passIfFound": true
        "configuration": {
    "customProperties": [
        "name": "hmRequestTimeoutInMs",
        "value": "59000"
