I developped an HTTP monitor.
In one step, I have to wait a few seconds before doing the next HTTP requests, and I have 2 issues:
1. Contrary to Browser monitors, we don’t have the option “Amount of time to wait before the next event is triggered”
Are you planning to add it?
2. The only way I found to do a wait, was to use some not great Javascript codes.
And I got another issue: if I put more than 1000 ms, I obtain a Script execution timeout error.
I tried to change the option “Adapt request timout” to 10s (which is normally already the case).
But It doesn’t work too: I don’t know why, but the step can’t take more than 1 second.
Is it a bug? Or is this restriction registered in another settings in Dynatrace?
If yes, where?
Many thanks in advance for your answer,
Kind Regards,
Sabine
1) I am not aware of any plans to add a wait option for HTTP Monitors.
2) There are some suggestions here for inserting a wait.
As you found the default timeout out for a pre- or post-execution script is 1s, so using the
https://postman-echo.com/delay/2
suggestion gets around this by using another request which you can adapt the timeout up to 60s.
We are planning to make the pre- or post-execution script timeout be modifiable (up to 10s). This is currently part of a preview, so if the postman alternative is not suitable you can speak to your CSM or Sales Exec about joining the HTTP Monitors Advanced Settings preview.
The only ‘solution’ that I could find re: a delay between steps in Dynatrace Synthetic Monitor is using https://postman-echo.com/delay/2. How/where do I use this, as a pre- or post-execution script, or as an HTTP standalone request between the two requests where a delay is required? How should it be configured/written within the request? I tried adding it as the latter, but it consistently fails with SSL_COMMUNICATION_ERROR.
Any help would be greatly appreciated!
Hi @eleone88 ,
requests cannot be added to pre- or post-execution scripts. The way to add the wait is to add another HTTP request in between the other 2. You need to set the request url to be https://postman-echo.com/delay/2.
