Is Cloudera supported?
Does someone know if Cloudera is supported by Dynatrace? As far as I know, Cloudera is based on Hadoop. Hadoop extension is available. So, was it possible monitoring Cloudera with Hadoop extension?
Is Cloudera support in roadmap?
Thanks in advance.
Elena.
Hi @erh_inetum
As per Dynatrace:
Alternative solutions:
  • You can follow the same method of Hadoop extension and give a try till official announcements.
  • Reach out to Dynatrace product expert in case urgent confirmation or update is required.
  • Custom extension might be an option.
Hoping it helps.
BR,
Peter
