Hadoop Hbase process monitoring
Hello ,
Is there a way we can monitor the Hadoop Hbase services?
In the Dynatrace Global settings we do have Hadoop HDFS & YARN extensions enabled . But haven’t found anything related to Hbase.
In the Dynatrace Hub ,we do have one Hadoop extension but unfortunately it will also monitor HDFS & Yarn services but not Hbase.
Here you have a description of all the Hadoop monitoring capabilities that are available out-of-the-box:
Otherwise you have to use the API or create your own plugin.
Radek
