Is it a UX bug applying $variables in Dashboard?
creating a widget in a custom dashboard,
Consider that DQL
fetch logs
| filter not matchesValue(content, array($IGNOREDERRORS))
Consider that $VARIABLE
The options are effecting the filter choosing the values required
but let’s suppose i want to empty the options in the $Variable, they became unavailable
but they still effecting the filters
even if i refresh the ux, they stay set, even if i reload the dashboard, removing all the query param from the url.
only if i go with “reset to default” they really go away,
but probably in the moment in which i manually change values of $variable, the UX should “reset to the default” by itself and then reload it.
Hi @andreabisello
That is done by design. If you remove the query param from the URL or reload the page, you’ll still see the variable values since they’re stored in the user app state. So by removing the options, the variable values are not affected.
