Dashboard Gen3 - default behavior of variable filter
Hello everyone !
On a new dashboard, I’ve set up 2 variables for filters and I would like the default selection to be “Select All” each time the dashboard is displayed, but not when it is simply refreshed. The current behavior is that the previous selection is remembered, and this does not adapt well to the actual values returned by the filter variables. I haven’t found a way to do this… is it possible?
Thank you in advance
Gerard
It seems that this will answer my question
Now you can set a default value for the variables you want to use on dashboards gen3
