As far as I know, not via DQL alone.
You can query the extension configuration entities/IDs in DQL, but the actual monitoring configuration content is exposed through the Extensions 2.0 API, not directly through DQL.
In practice, the supported way is to use the configuration ID you get from fetch dt.entity.extensions:configuration and then call:
GET /api/v2/extensions/{extensionName}/…
here documentation: Extensions 2.0 API
That endpoint returns the configuration payload in the value field.
So today the answer seems to be: IDs in DQL yes, full contents in DQL no.
