For example, I’d like to get a list of all of our configured Davis Anomaly Detectors that contain the word “Mail” in them so that I can easily pass on a report of what alerts are setup for our Email (Exchange) team.
I don’t see a way to do this with the current fetch commands, as they only allow you to query the Davis Events and Problem tables which are for alerts/events that have triggered. I want a list of what’s configured that could possibly trigger.
And really, that’s just one example. In general, I’d like to be able to query other configuration settings via DQL so that I can easily see how things are set without having to go do an API call to the Settings API via PostMan or Swagger every time.
I don’t believe this is possible. You should be able to do it via the custom Javascript code in a notebook though.
I’ve not tested it but it should work. More info here.
KR.
Michiel
@36Krazyfists configuration is not exposed via DQL in Grail. But it’s accessible through platform API or TypeScript SDK - for Davis Anomaly Detectors in particular this SDK Davis® AI - predictive and causal | Dynatrace Developer
So you can easily set up a workflow in Dynatrace , query the Davis Analyzers and send out a report from the workflow. See the JavaScript code examples in the SDK docs for examples how to use it.
If you haven’t done so already, check out the Dynatrace CLI (dtctl). It makes pulling data from the tenant way easier than having to fall back to Swagger or Postman. The Settings API is available via dtctl, both for read and write.
