Is there a way I can monitor slow queries on the database and discover which code originated this slow query?
I can see some queries on the Database section and get some information from PurePath on Transactions and Services, but I can’t seem to find a way to know where the query was generated, like a complete stacktrace that shows which files (and which line) generated this query (I’m running a PHP application).
As your question relates to our Dynatrace SaaS and Managed offerings, I’ll move this question to the appropriate forum. (Because “AppMon & UEM Q&A” relates to one of our classic products.)
In Dynatrace you don’t get it at the Purepath level, even when seen in “Code level”. But given that PHP is (normally) interpreted, it might be possible. So probably this might be better considered an RFE.
It’s a different case in errors, where that information is available:
Nowadays you should also be able to get all the database queries and their response times and other metrics, from the database details under Database. If the information displayed is not specific enough, you can create your own multidimensional analysis views, and save them for the service.
