Hello.
Is KVM supported for Dynatrace SaaS ?
KVM is described in Virtualization monitoring Dynatrace, but I don’t have confidence.
Thanks.
Hello.
Thanks.
As you found KVM is listed as supported under virtualization:
https://www.dynatrace.com/support/help/technology-…
And after a quick browse I don’t see any issues or anything reported so I don’t see why it wouldn’t be supported.
James
Thank you for your support.
Nobuhiro
Of course you will have to install Oneagent in each KVM virtual machine. Running Oneagent on the host where your KVM VMs are running will not help you to monitor the applications running the in VMs.
