Hello community!
I am creating a JMX extension 2.0 via VS code extension, and I want to add release notes and Product information.
I have searched the docs, but I am not able to find anything relevant. (hope I have not missed anything
I would really appreciate if you can share any insights on this
Thanks in adv!
- Sahil
Hi @Sahil23 ,
Here you can get an example of how to add the version and other information
And here you can find a video to create JMX extension 2.0 via VS code extension.
Hope it helps.
Elena.
Hi @erh_inetum ,
I went through these, there’s no mention about how to add Product information in these video/doc.
Hi @Sahil23 ,
In the yaml you can add some kind of information.
Ex:
# required extension metadata
version: 1.0.0
minDynatraceVersion: 1.265.0
author:
Is this that you need?
Elena.
Hi @erh_inetum,
I was referring to the above highlighted section!
Hi @Sahil23 ,
It’s not possible for the time being but Dynatrace is considering to implement it as you can see here.
You can create a product idea for that.
Hope it helps.
Elena.
