I am trying to enabled Dynatrace monitoring for Red Had JBoss DataGrid Infinispan.
I used the Dynatrace 1.0 JMX Wizard to find the Infinispan process and add the metrics into a custom extension for 1.0.
With the resulting zip file, I extracted the JSON. Then I tried to use the VSCode plugin for Dynatrace Extensions 2.0 to translate this 1.0 JSON to the 2.0 version.
However I get errors.
The 1.0 JSON contains items such as:
- type: METRIC_TABLE
- mode: NORMAL
- metrics > metricSelectorSort
- metrics > metricSelectorDetailed
What the the Ext 2.0 equivalents for these?
Since these are terms coming from a Dynatrace 1.0 JSON, should these not automatically be covered by the VSCode plugin for conversion to 2.0?
Please help as we need to resolve this in a matter of days.
