k8s problem
If Kubernetes cluster anomaly detection is enabled, will there be additional resource consumption, such as ddu, or cluster node overload
thanks
Enabling the anomaly detection will not consume any DDUs, and i believe it will not put any load on the cluster node as the data is already collected and analyzed, you can check the below document for further details.
Islam
Okay, thank you. I’m worried it might affect the system.
