I’m using the Kafka extension and I would like to know how to filter several topics in the “Topic name filter” field located in the configuration steps.
Thanks for your help
Best regards,
Best regards,
Does extension not allow more than one name? Tags?
Best regards
Hi @JMBMinint,
Could you please try this. I have never tried it in this way but maybe it will work.
OS services monitoring — Dynatrace Managed Docs
I hope it helps.
Best regards,
János
In which view do you want to apply filters?
Best regards
Thanks for your replies, I solved this by symply using one configuration per topic.
Best regards,
Jean-Michel
