We want to monitor applications in Kubernetes but have strict access limitations:
- Managed Kubernetes cluster
- No privileged DaemonSets allowed
- No hostPath / host access
- Access limited to specific namespaces only
- Custom ServiceAccount with read-only RBAC (get/list/watch on pods, workloads, services, and metrics APIs)
We cannot deploy Dynatrace OneAgent as a DaemonSet or use cluster-level components.
Question:
What is the officially supported way to monitor applications only in this scenario?
Is application-only monitoring (e.g., webhook or code-level instrumentation) the recommended approach, and what limitations should we expect?
Maybe this table might help.
Best regards
With your constraints (no privileged DaemonSets, no hostPath/host access, namespace-only access, no cluster-level Dynatrace components), you cannot deploy Kubernetes Full-Stack monitoring based on a node-level OneAgent, nor the usual Kubernetes deployment model that relies on cluster-scoped components. The Dynatrace Operator is inherently cluster-scoped (ClusterRole, etc)
You effectively have two supported “application-only” paths (no host-level):
1. Dynatrace Application Monitoring / Application Observability (app-only, no OneAgent DaemonSet on nodes)
- Monitoring is done by injecting Dynatrace code modules into application Pods (for example via init containers / build-time approaches), without installing OneAgent pods on every node and without host metrics.
- If the Operator isn’t involved, Dynatrace explicitly notes you lose automatic injection/config/enrichment and must manually adapt your workloads.
Documentation here: Application observability — Dynatrace Docs
2. Opentelemetry, I mean export OTLP to Dynatrace.
Is application-only the recommended approach here?
IMO Yes. Given your constraints, it’s essentially the only practical, officially supportable route. Host/network-level features require components/privileges you can’t deploy (for example, CSI-related capabilities can require privileged permissions in typical setups). Dynatrace Operator — Dynatrace Docs
limitations:
No host-level infrastructure visibility and mabye limited Kubernetes platform/topology view, because without Dynatrace cluster components and broad K8s API access. But here you can do something like here:
