Kubernetes Configs in Dynatrace? (Like what Kiali has)
Is there a way I can get Kubernetes configs (like for pods, containers, namespaces, etc.) into Dynatrace? I have some developers who are using Kiali to fill this need and are asking if they can see these data in Dynatrace and so far I don’t see a way but I’m wondering if anything is either on the roadmap or possible someway (like via API?).
@shakib You can get all these details in Dynatrace easily. By default Dynatrace provide “Kubernetes” option in menu. Once you click this you will have all required data.
Tijust
Hi @shakib,
AFAIK Kiali is a Istio Service Mesh monitor. You can find some information regarding Dynatace Istio Service Mesh extension here:
Istio Service Mesh monitoring & observability | Dynatrace Hub
I hope it helps.
Best regards,
Mizső
I’ll give that Istio extension a try, for some reason I didn’t see it before. I’ll report back once I chck it out. Thank you.
