Kubernetes Events - Davis
I am checking in the Kubernetes monitor integration which events are collected from OCP. I just see node events:
I don’t see Application or Namespace events.
On the other hand, there are Warning events about checking limits from nodes and NodeNotready events and I don’t see a problem detected by Davis.
Are these Kubernetes events processed by David in order to detect a problem?
Thanks in advance.
Alberto.
Within your Kubernetes settings, you can include additional events:
As of right now, Cluster level is only done via the API, so Davis is not incorporated I don’t believe.
Hi Chad,
I currently have selected both Node and Pod events. But, the events do not seem to be considered for “alerting”, and there seems to be no other place where one can configure which specific events to be alerted on. For example: Node NotReady status.
Thanks. Tibebe
I understand that to date it does not send alerts, it only collects information on events.
Were you ever able to solve this?  Seemed like the simplest approach would be with a “simple workflow” as documented here.  I’m curious whether there’s a more “Dynatrace-native” approach.
