Limit of number of metric dimension values
I am working with metrics event and metric selector.
I don’t understand why there is so much dimensions with this simple request :
  • sql-server.host.cpus:splitBy(“dt.entity.sql:sql_server_host”):max:rollup(avg,5m)
In Data Explorer there is only 76 “dimensions”
Also the documentation is unclear about the behavior once the limit has been reached :
  • THROTTLED: The configuration reached the query limits of the metric selector.
Does the alert stop working for the next 24 hours?
Thanks for your help :slightly_smiling_face:
I would split it per host groups or hosts, if that is possible. It means, creating more than one and filtering entities.
Best regards
Thanks @AntonPineiro . Sadly adding splitby fields does not change the number of dimension in my case.
I do not see another option than reduce scope. Maybe, you can ask Dynatrace ONE or raising some product idea. It is design limitation.
Best regards
We have the exact same problem here , and we also have the same questions unanswered
sql-server.databases.state:splitBy(“dt.entity.sql:sql_server_database”,instance,server,database,“database.state”,“database.recovery_model”):filter(in(“dt.entity.sql:sql_server_database”, entitySelector(“type(sql:sql_server_database),tag(INOP-Plateforme-Bd:SB)”)),and(ne(“database.state”,RESTORING)))
I am also facing the same… in my case, I am testing the Davis Anomaly Detection app, with good results.
