When dealing with metric events, you might have to be careful with metric expressions. If not, you might get into situations like this one:
The Settings page has some links to the documentation,
but also a link to Data Explorer, which uses the following metric expression:
- dsfm:server.anomaly_detection.metric_events.monitored_dimensions:splitBy(“dt.config.name”):last:sort(value(auto,descending)):limit(50)
When looking for a good usage of metric expressions in the context of metric events, you should monitor this well, so you don’t get affected by throttling.
