Link URL for DEM
Dear All,
We have a question. When we warp applications,We will use the URL we created to connect to the internet web machine (Please refer to diagram on the pink arrow) and then send the web to the Cluster Activegate, Can we do it? We will not provide information from mobile applications directly connected to the Cluster Activegate . Please find as the picture diagram.
Thank you.
I’m not really sure what you want to achieve. The Cluster ActiveGate is typically not used when monitoring web applications, except in the case you are using the browser extension or manual instrumentation, which does not seem to be the case here. Normally real user monitoring beacons are captured on the first Oneagent monitored process in the chain.
Cluster ActiveGate is, however, required when monitoring mobile applications. You have to provide the URL to cluster active gate as part of the instrumentation of the app.
