Hi Folks,
Does anyone know when will be available a new live test system similar to the DEMO LIVE environment with the new Dynatrace GUI (announced on Perform 2023)?
Thanks in advance.
Best regards,
Mizső
Hi Folks,
Thanks in advance.
Best regards,
Mizső
Hi @Mizső in my case it appears briefly below the accounts section, but now it suddenly disappears.
As partner I asked to support team to enable it on our tenant but it is not possible right now because GA will be there in few weeks. I think Dynatrace polishing last details for this new Experience! ![]()
Hi @jegron,
Thanks for the info, I am trying to be patient as partner… it is very difficult… 😉
Best regards,
Mizső
Here you go:
Try demo.live.dynatrace.com . When page loads, change the "live"in URL by “apps”. And then, you should be with new ui.
WOOOOW!!!
