Deploy Dynatrace Page
Where is the “Deploy Dynatrace” option gone?
It was a combo selection of all the integrations.
It seems it’s missing into my console, please assist.
SaaS Grail? SaaS? Managed?
SaaS Grail. I see it’s there on the older UI.
Yes, some of the stuff is still in the old UI, like API access links as well.
Does, that means we’ll have to switch around.
Hello @munawarhossain1
I could see this under my app as Deploy OneAgent if looking for integration then select Hub under apps.
Cheers!
RN
I was thinking same but it is not exact same view. I think @munawarhossain1 is asking about that landscape page where you can select what you want to do as install OneAgent, ActiveGate, Synthetic Monitors, etc.
I do not see a way to find it in new Strato UI. Maybe, it can be a product idea.
Best regards
Yes true this view has completely gone. Now everything in this view has changed into apps.
Yes, now there is a new view and not everything has been transferred perfectly to it. However, I think it is a matter of time.
