I have open a ticket to Dynatrace about why traces don’t have log.
Then based on the documentation provided, the understanding is that these fields/header needs to be present for the trace-log correlation to works.
But then what I see in customer environment isn’t that.
As you can see below:
I can see the trace highlighted has logs for it when I open with ‘open logs of this trace’
Since this correlation works, so by right there should be values in either of these 3 fields: dt.trace.id, dt.span.id, dt.trace_sampled.
But then when I add these 3 fields to the query, they are all null!!
So right now I really don’t know how all this works actually. (And if the 3 fields aren’t necessary for the correlation to work then I’ll be very curious on what basis the Dynatrace Support revert to us that the correlation doesn’t work because there 3 fields are null)
Best Regards,
Wai Keat
