Hello everyone, I need some help configuring log correlation manually, I enabled the OneAgent Features but my logs are not correlating with problems and most of the trace IDs are missing.
Hi Natanael,
I would very much appreciate it if you could describe in more detail what correlation you need to do? Additionally, do you want to do it on Dynatrace SaaS or Managed?
Radek
is on Dynatrace SAAS, all automatic correlation are enable but when the logs come to the log page they didnt contain the Trace ID, dont correlate and the logs are just log, without any useful purpose
