Self Service Summary
Customers see that the disk utilization was below the threshold, however, Dynatrace didn’t trigger problems for the low disk space.
Host/Global setting for anomaly detection was enabled and Disk was below the threshold.
Troubleshooting
Please check if Custom disk-detection rules are configured and enabled.
The custom detection Rule Overrides the global anomaly detection rule and sets the disc detection and threshold on them.
If this Custom disk-detection is DISABLED then it will stop the monitoring of those detected disks for anomaly detection and the problem will not trigger.
Solution
The solution is to either remove the disk from the Custom disk-detection rule OR delete the Rule if not required
