Hi all.
I have 5 Requests to unmonitored host, and I need to create a daily maintenance window at 10pm
Someone could help me? Only solution I see is to MUTE those requests?
Thanks in advanced.
BR
JoseA
Hey Josean.
Goto Settings > Maintenance windows > Maintenance windows for monitoring, alerting, and availability > Create Maintenance window
In here.
You can do this in 2 ways,
1. Use the Entity filter and add the service “requests to unmonitored hosts” to the maintenance windows.
2. You can also use the tag associated with that service and add that tag to set up a maintenance window for the service and the requests under that.
Thank you theharithsa
One more question, how do I tag the request?
From Automatic apply tag I don’t see this request. What filter should I apply? service? service Name?
Thanks in advanced.
jose A
That isn’t possible unfortunately.
What you can do, is split the “Requests to unmonitored hosts” service into multiple services and than apply a maintenance window to one of those.
Not sure how to do it using the UI, but there is an API for it, see: New Dynatrace API enhances automatic service detection | Dynatrace news
