Maintenance window in response time metrics
Possibility of creating a maintenance window in the response time metrics. To avoid nightly server restarts
@jmmatia1
I don’t quite understand what you would like to achieve:) Maybe describe your issue in more detail?
Radek
  • Just as there are metrics that exclude maintenance windows:
    Availability rate - excl. maintenance windows (by location) [browser monitor].
    I would like to be able to configure a VM to exclude response time (performance) metrics from maintenance windows when there are server reboots
Unfortunately, there is no option in the Maintenance Windows settings that you are looking for. This can be set at the host (or group host) or process (or group process) level. Alternatively, try to narrow the area with tags, but only to the level of a single process.
I believe you can achieve that by using tags, please check the below document for that.
Yes, but he will not narrow down to a specific metric (Response Time) - as I wrote
