Maintenance window usage
Hi, there
Is it feasible to suppress an alert based on metric event and host name? At present, I don’t see an option but would like to know if there’s any way of getting this done.
Srikanth
You need to create a maintenance window and define scope.
Best regards
Hi Srikanth,
Nowadays it’s not possible to create maintenance window for a metric events.
There are created these two product ideas:
https://community.dynatrace.com/t5/Product-ideas/Maintenance-Window-for-Metric-Events/idi-p/212834
https://community.dynatrace.com/t5/Product-ideas/Add-maintenance-window-to-Log-or-Metric-Events/idi-p/211608
There aren´t planned for the time being. But on these posts you can find a proposed workaround.
Hope it helps.
Elena.
Thanks for your response, Elena.
Unfortunately, above links you have shared won’t cater my current need. I’ll try to explore in the event management system (not in Dynatrace for now).
