How do we suppress Suppress Default Metric event like “Oracle - Backup Failed” , “Oracle DB Unreachable” during maintenance windows?.
@sundarv1 Are you looking to suppress alerts from extensions (Oracle?) .
Is setting a maintenance window with “disable problem detection during maintenance” still triggering alerts in your case?
Could you please elaborate bit further
As you can see here, you cannot apply maintenance window only to a single metric.
It should be in entire entity, as database instance, DB Server…
Best regards
