Hi Team,
Is there any way to suppress a specific alert like CPU saturation on a particular host?
Hi Team,
Hן @Vikas_g1997
With anomaly detection setting - Host level you will be able to set problem-creation thresholds or switch them off.
HTH
Yos
Hi @Yosi_Neuman.
Thanks for the suggestion. Can we do it for a specific timeframe as we do it in Maintenace Window?
Hi @Vikas_g1997
There is no why to do that from anomaly detection perspective.
May be you can utilize for that Host anomaly detection API - PUT configuration
Yos
Hi @Yosi_Neuman ,
I’ve a similar requirement where CPU alerts (alerted through metric event) for a specific host has to be suppressed permanently.. Is there a way to do it? Explored maintenance window option but unable to figure out any option that can handle this..
Srikanth
@Yosi_Neuman - Do you think adding a dimension filter like below in the metric event would avert alerting for a specific host?
dt.entity.host.name does not contain (case sensitive) xxxx.domain.com
Thank you @Yosi_Neuman @.. It’s one of the option, I was thinking to go for this morning.
Could you please share the steps and screenshot what you have done to suppress CPU usage for host level?.
hi @Vikas_g1997
you can disable it on host or host group level through anomaly detection settings.
Thanks.
Hi Peter
In the maintenance window(in the above screenshot) - How to suppress alert for one host and only CPU saturation and only for time period daily 1.00a.m to 5.00a.m
Hi @sundarv1
simply specify the entity ID for example HOST-Abcdefghihjk4545454 and entity tag if there
select the duration to once and allocate the suggested timeframe as per your time zone, below are samples.
Peter
Thanks. This will stop all alerts for the CI. How do we stop only CPU Saturation alert alone?.
Hi Samar - Does the above solution worked to suppress CPU alerts only during specific period. if so please share steps.
I still don’t see an option to use specific event type in the maintenance window. I’ve submitted RFE, pls refer below.
Specific event type suppression in maintenance window - Dynatrace Community
