Suppress Log Monitoring Metric Extraction, which is created under “Log Monitoring - Event Extraction” during maintenance windows.
@sundarv1 Are you looking to suppress the alerts that are created by log metrics? Is setting a maintenance window with “disable problem detection during maintenance” still triggering alerts in your case?
Could you please elaborate bit further
How do we disable one log metric out of 50 in the maintenance window
This is not the solution. We are doing log monitoring based on errors in the log file in the server. We want to suppress the log monitoring alone during maintenance window
