I’m trying to make the dashboard panels to fit to the display. I don’t see any settings related to the panel sizing, could you please share if there is any workaround to make the dashboards fit to display.
can you provide a screen cap of the item in question? Just not sure if you are in the classic dashboards, notebooks etc…
Hi Chad, I think I’m in classic dashboards
If you click edit on the upper right you will have the ability to resize the tile(s)
yes i can increase/decrease size of the panel but i’m looking for auto fit or something that will shrink based on the display size.
if the display is not so big, I have to scroll left and right.
I think that is not possible, it might be a product idea.
Best regards
