Manage workflow as code instead of drag-and-drop visual blocks
Is there a “developer UI” that can manage workflow as code instead of drag-and-drop visual blocks?
Using Dynatrace’ configuration as a code tool Monaco allows you to manage automation as code at scale.
Video recordings that can be helpful:
Introducing Monaco 2.0 – Dynatrace Configuration as Code
https://community.dynatrace.com/t5/Dynatrace-tips/Introducing-Monaco-2-0-Dynatrace-Configuration-as-Code/td-p/208460
Dynatrace Tips & Tricks – Episode #9 with Arijan Zenuni - Monaco 2.0
https://community.dynatrace.com/t5/Dynatrace-tips/Dynatrace-Tips-amp-Tricks-Episode-9-with-Arijan-Zenuni-Monaco-2/td-p/208447
