Managing Dynatrace Automation Workflows as Code with dtctl and GitHub Copilot
Infrastructure as Code for Dynatrace Workflows — a field guide from the trenches
Why Workflows as Code?
Dynatrace Automation Workflows are powerful — but clicking through the UI to build and maintain them doesn’t scale. Once you have more than a handful of workflows, you want:
- Version control — know who changed what and when
- Reproducibility — deploy the same workflow reliably, every time
- Code review — catch logic errors before they hit production
- Copilot assistance — let AI help you author complex JavaScript tasks and DQL queries
This guide walks through the full cycle: using dtctl (the Dynatrace CLI) together with GitHub Copilot to author, deploy, and version-control Dynatrace Workflows as YAML files.
Prerequisites
- dtctl installed and configured (~/.config/dtctl/config) with a valid context pointing to your Dynatrace environment
- A Git repository to store your workflow YAML files
- GitHub Copilot active in VS Code
Verify your context is working:
dtctl get workflows | head -5
The Workflow Cycle
Copilot generates YAML → dtctl apply → test in DT UI → git commit → PR
Simple. Let’s walk through each step.
Step 1 — Export an Existing Workflow as a Reference
Before writing from scratch, export a working workflow to understand the schema:
# List all workflows
dtctl get workflows
# Export a specific workflow to YAML
dtctl get workflow <workflow-id> -o yaml
The exported YAML is the ground truth for the API schema. Use it as a starting point and ask Copilot to adapt it to your use case. Any workflows already living in your repo are equally good templates.
Step 2 — Author a New Workflow with Copilot
When prompting Copilot, be specific about three things:
- Trigger type: davis-problem, davis-event, or schedule
- Tasks: JavaScript logic, DQL queries, ServiceNow calls, email notifications
- Conditions: when tasks should run or be skipped
Here are the three trigger types with correct YAML structures — including some non-obvious gotchas I hit along the way.
Davis Problem trigger
trigger:
eventTrigger:
filterQuery: >-
event.kind == "DAVIS_PROBLEM" AND event.status == "ACTIVE"
AND matchesValue(event.status_transition, {"CREATED", "UPDATED", "REOPENED"})
AND matchesPhrase(affected_entity_names, "MY_HOST")
isActive: true
triggerConfiguration:
type: davis-problem
value:
analysisReady: false
categories:
custom: true
customFilter: 'matchesPhrase(affected_entity_names, "MY_HOST")'
entityTags: {}
entityTagsMatch: "all"
onProblemClose: false
problemOpenDuration: null
severityThreshold: null
triggerOn: null
triggerOnUpdateFields: []
uniqueExpression: '{{ event()["event.id"] }}-{{ "open" if event()["event.status"] == "ACTIVE" else "resolved" }}-{{ event()["dt.davis.last_reopen_timestamp"] }}'
Davis Event trigger (e.g. PGI_CRASHED_INFO)
trigger:
eventTrigger:
filterQuery: >-
event.type == "PGI_CRASHED_INFO"
AND matchesPhrase(event.description, "MyProcess")
AND dt.entity.host == "HOST-XXXXXXXXXXXXXXXX"
isActive: true
type: davis-event
value:
entityTags: {}
customFilter: 'event.type == "PGI_CRASHED_INFO" AND matchesPhrase(event.description, "MyProcess")'
uniqueExpression: '{{ event()["event.id"] }}-{{ event()["event.start"] }}'
Gotcha: For davis-event, the value object only accepts entityTags, entityTagsMatch, and customFilter. Fields like eventName, problemState, and eventTypes are not valid and will cause a 400 error. Copilot sometimes generates these — always validate with dtctl apply --debug.
Schedule (CRON) trigger
trigger:
schedule:
filterParameters: {}
inputs: {}
isActive: true
nextExecution: null
rule: null
timezone: America/Toronto
trigger:
type: cron
cron: "5 20 * * 0" # Sunday 20:05 local time
Gotcha: The cron expression goes in the nested trigger.cron field — not in rule. The rule field must be null or a valid UUID. Setting it to a cron string causes a 400 error.
A Complete Workflow Example
Here’s a full, deployable workflow that ties everything together. It listens for a process crash event, suppresses the alert during a known maintenance window, then creates a ServiceNow incident via a shared workflow.
title: HealthCheck - MyService - Process Crash Alert - MYSERVER01
isDeployed: true
description: >
Creates a ServiceNow incident when MyService.exe crashes on MYSERVER01.
Suppresses alerting during the Sunday 20:00-20:05 scheduled maintenance window.
actor: <your-actor-id>
owner: <your-owner-id>
ownerType: USER
isPrivate: false
schemaVersion: 4
trigger:
eventTrigger:
filterQuery: >-
AND matchesPhrase(event.description, "MyService")
isActive: true
type: davis-event
value:
entityTags: {}
customFilter: 'event.type == "PGI_CRASHED_INFO" AND matchesPhrase(event.description, "MyService") AND dt.entity.host == "HOST-XXXXXXXXXXXXXXXX"'
type: STANDARD
hourlyExecutionLimit: 1000
tasks:
check_maintenance_window:
action: dynatrace.automations:run-javascript
description: >
Returns inMaintenanceWindow=true if current time falls inside the Sunday
20:00-20:05 scheduled restart window. Handles DST by checking both UTC offsets.
input:
script: |
export default async function () {
const now = new Date();
const utcDay = now.getUTCDay();
const utcHour = now.getUTCHours();
const utcMin = now.getUTCMinutes();
const inSummerWindow = utcDay === 1 && utcHour === 0 && utcMin < 5;
const inWinterWindow = utcDay === 1 && utcHour === 1 && utcMin < 5;
const inMaintenanceWindow = inSummerWindow || inWinterWindow;
console.log(`UTC day=${utcDay} hour=${utcHour} min=${utcMin} | inMaintenanceWindow=${inMaintenanceWindow}`);
return { inMaintenanceWindow };
position:
x: 0
"y": 1
predecessors: []
prepare_snow_payload:
active: true
conditions:
custom: '{{ result("check_maintenance_window").inMaintenanceWindow == false }}'
else: STOP
states:
check_maintenance_window: OK
description: >
Builds the ServiceNow incident payload. Only runs when the crash occurs
outside the scheduled maintenance window.
input:
script: |
import { execution } from '@dynatrace-sdk/automation-utils';
export default async function ({ execution_id }) {
const ex = await execution(execution_id);
const ev = ex.params.event || {};
const payload = {
serviceNowPayload: {
cmdb_ci_input: "MYSERVER01",
assignment_group: "My Team Name",
u_impacted_system: "My Application",
caller_id: "dynatrace",
category: "Software",
subcategory: "Application",
contact_type: "Alert",
correlation_id: `DT_${ev["event.id"] || ""}`,
short_description: "MyService crashed on MYSERVER01",
description: [
`Dynatrace detected a process crash on MYSERVER01.`,
`Process : MyService.exe`,
`Time : ${ev["event.start"] || new Date().toISOString()}`,
`Event ID : ${ev["event.id"] || ""}`,
`The service may have restarted automatically.`
].join("\n"),
priority: "3",
state: "1",
environment: "Production",
environment_type: "PRD",
options: { search_cmdb_ci_by_fqdn: "N" }
original_event: ev
return payload;
position:
x: 0
"y": 2
predecessors:
- check_maintenance_window
create_snow_incident:
action: dynatrace.automations:run-workflow
active: true
conditions:
states:
prepare_snow_payload: OK
description: Calls the shared ServiceNow Incident Creation Workflow.
input:
workflowId: <your-snow-workflow-id>
workflowInput: '{{ result("prepare_snow_payload") }}'
position:
x: 0
"y": 3
predecessors:
- prepare_snow_payload
Three tasks, one conditional gate:
- check_maintenance_window — always runs; returns a boolean
- prepare_snow_payload — runs only when inMaintenanceWindow == false; stops the chain otherwise
- create_snow_incident — delegates to the shared SNOW workflow, passing the prepared payload
Save this as HealthCheck-MyService-ProcessCrash-MYSERVER01.yaml and deploy with dtctl apply -f.
Step 3 — Deploy with dtctl apply
cd ~/projects/dynatrace-workflows
# Create a new workflow (auto-generates an ID)
dtctl apply -f MyWorkflow.yaml
# Stamp the generated ID back into the file for future updates
dtctl apply -f MyWorkflow.yaml --write-id
# Update an existing workflow (file must already contain the id field)
The output tells you whether the workflow was created or updated. Use --write-id on first deploy so the file becomes self-contained for all future updates.
Step 4 — Diagnose 400 Errors
When dtctl apply returns a 400, run with --debug to see the full API error body:
dtctl apply -f MyWorkflow.yaml --debug 2>&1 | grep -A 10 '"error"'
The response includes a details object that pinpoints the exact invalid field:
"trigger": {
"eventTrigger": {
"triggerConfiguration": [
"davis-event -> value -> eventName: Extra inputs are not permitted"
This tells you exactly which field to remove or fix. Much faster than guessing.
Step 5 — Test the Workflow
Workflows with event triggers can’t be tested by injecting synthetic events via the Events API — PGI_CRASHED_INFO and similar types are OneAgent-generated. Use the manual run feature in the Dynatrace UI instead:
- Go to Automations → Workflows → open your workflow
- Click Run (top right)
- Paste a mock event context JSON:
"event.type": "PGI_CRASHED_INFO",
"event.description": "Process MyService.exe has crashed",
"event.start": "2026-01-01T13:00:00.000Z",
"event.id": "test-event-001",
"dt.entity.host": "HOST-XXXXXXXXXXXXXXXX"
- Verify each task ran successfully and check that any downstream integrations (SNOW, email, etc.) fired correctly
Note: Manual test runs do not create Dynatrace problems or inject real events. They only execute the workflow tasks with the provided mock context.
Step 6 — Commit to Git
cd ~/projects/my-dynatrace-repo
git add dynatrace-workflows/
git commit -m "Add/update workflow: <description>"
# Use a feature branch — main typically requires PR + CI checks
git checkout -b feature/my-workflow-change
git push -u origin feature/my-workflow-change
Then open a PR. Treat workflow YAML the same as application code — review it, scan it, merge it.
Bonus: Calling a Shared Workflow (ServiceNow Integration Pattern)
A pattern that works well at scale is a shared integration workflow that handles ServiceNow incident creation, with individual alert workflows delegating to it. This avoids duplicating SNOW logic across dozens of workflows and gives you a single place to update the integration.
Preparing the ServiceNow payload (JavaScript task)
const ev = execution.params.event ?? {};
const payload = {
cmdb_ci_input: "MY-HOSTNAME",
correlation_id: `DT_${ev["event.id"]}`,
short_description: "Alert: process crash detected on MY-HOSTNAME",
description: `Event ID: ${ev["event.id"]}\nHost: ${ev["dt.entity.host"]}`,
priority: "2",
state: "1",
options: {
original_event: ev
return payload;
Calling the shared SNOW workflow from YAML
input:
Common Gotchas at a Glance
Issue Cause Fix
| 400 on davis-event trigger | Invalid fields in value (e.g. eventName, problemState) | Only use entityTags, entityTagsMatch, customFilter |
| 400 on schedule trigger | Cron string in rule field | Put cron in trigger.cron, set rule: null |
| Push rejected to main | Branch protection / CI required | Use feature branch + PR |
| PGI_CRASHED_INFO not triggering | INFO-level event, not a Davis Problem | Use davis-event trigger type, not davis-problem |
| contains() not allowed in filterQuery | filterQuery uses a DQL matcher subset, not full DQL | Use matchesPhrase() instead |
Quick Reference: Useful dtctl Commands
dtctl get workflows
# Export a workflow to YAML
dtctl get workflow <id> -o yaml > my-workflow.yaml
# Deploy / update
dtctl apply -f my-workflow.yaml
# Deploy and stamp ID into file
dtctl apply -f my-workflow.yaml --write-id
# Debug a failed deploy
dtctl apply -f my-workflow.yaml --debug 2>&1 | grep -A 20 '"error"'
# View execution history
dtctl get workflow-executions --workflow <id>
# Get task result from a specific execution
dtctl get wfe-task-result <execution-id> <task-name>
Wrapping Up
The dtctl + Copilot combination makes managing Dynatrace Workflows as code genuinely practical. Copilot handles the boilerplate YAML and JavaScript task logic; dtctl apply --debug gives you precise, field-level error feedback when the API rejects something; and Git gives you the full audit trail.
The main things to remember:
- Export a working workflow first — it’s the best schema reference you have
- Use --write-id on first deploy — keeps the file self-contained for future updates
- davis-event trigger value is more restrictive than it looks — let --debug be your guide
- Manual run in the UI is your best testing tool for event-triggered workflows
Happy automating. If you’ve hit other gotchas or have workflow patterns worth sharing, drop them in the comments.
