Management zone automation using Dynatrace REST
Hi, can we achieve automation of management zones like creation, updation using REST APIs?
Yes you can create and update management zones through config API.
Best greetings,
Wolfgang
details: Management zones API — Dynatrace Docs
Hi Rajesh.
from Dynatrace API explorer, there are these options:
BR.
jose A
