Management zone in classic dashboard url
Hi guys,
Customer ask to cerate links to classic dashboard with directions to to different Management Zones
We can see in the url that there is parameter that change for each MZ we pick
For example :
Did not found any thing like that from v2 object settings, Any one knows from where we can get this id ?
Yos
Hello @Yosi_Neuman
PFA URL for validation:
Hoping it helps.
BR,
peter
Hi @Yosi_Neuman
I hope these ones will help you.
Configuration API Dashboards:
Env2 API Settings MZ (before you should collect the object id of the MZ from the Settings/Objects):
Best regards,
Mizső
Hi @Mizső
Thanks for the detailed explanation and screen shots.
The mystery form my end was how to collect the object id of the MZ from the Settings/Objects that is holding the right MZ id … will need to prepare a list of object id and summary to collect the right object id for the MZ api
Roger that
Yos
