Masking Sensitive Data to SHA-256
When using the SaaS platform and masking a value matched by a regex to SHA-256.  Is the hashed value a standard SHA-256 or is some kind of salt involved?
hi @croweman
Can refer the below document, Sensitive data masking in OneAgent — Dynatrace Docs
Its mentioned as,
  • If you select SHA-256, your data will be replaced by the 40-character hash string.
  • If you select replace with string, set Replacement to the string that is meant to replace your sensitive data.
No Salt involved :slightly_smiling_face:
