matchesPhrase not working as expected
I have a routing rule as matchesPhrase(aws.log_group, “123456”)
It picks up the log group with name /aws/lambda/test-123456-cit1-test1
but it does not pick up this one batch-job-123456-cit1-jd
Any pointer why this is happening like this ? Thanks in advance
hello @susmita_k to be able to help you, can you share with us the full command you are using. thanks
