How is the memory allocated to each different process in Managed? when I use vim command to view the Managed Installer, it Seems Like it is based on percentage:
If that’s really the case, is there anyway to tweak the configuration of Memory Allocation? (for example, through the edit of Xmx and/or Xms value of each process).
And if yes, what’s the best practice to do this?
Client currently using appmon, and has the…freedom to edit the memory allocation of FrontEnd Server and Server should such a need arise.
