Memory dumps download on ActiveGate from an AWS Fargate OneAgent in standalone
How do I download memory dumps to an ActiveGate? We have an AWS Fargate OneAgent installed but we get an error that says the OneAgent is in standalone mode.
The Memory dumps are only created on the Local OneAgent directory.
It depends on what method of AG you are using. Dynatrace is leveraging containerized AGs by default which can be beneficial but really isn’t an enterprise solution in my mind. Main point being, you cant use it to do memory dumps:
And since the containerized method only gives you the partial functionality, why would you bother using it? you could stand up a single AG which would then support all your current and potential future needs.
To read more on the functionality check this link out:
