We run all our workloads in AKS Clusters and we have Dynatrace integrated via the Kubernetes Classic full-stack injection or Cloud-native full-stack injection. With my current setup, I am able to trigger memory dump but I am not able to download the triggered dump directly from Dynatrace.
Upon some reading, I understand that the active gates have to be configured to enable such direct download, but I am having a hard time figuring out how I can accomplish that configuration in the Dynakube-based Kubernetes integration. I assume some configurations needed to be updated in the Dynakube to reflect the configurations outlines in Configure ActiveGate for memory dump storage — Dynatrace Docs
Need some help to get this set on my environment, thanks in advance.
You would also need an accessible downloadUrl to retrieve the memory dump files. I believe this requires an ingress (such as a gateway with Istio) to be able to retrieve the dump from outside of the cluster:
I’ve heard of reported issues, such as the following:
dump path not matching (eg: volume storage is/not used, so the relative path doesn’t match what ActiveGate is expecting)
Memory dumps are a “stop-the-world” event, so they could cause liveness probes to fail, therefore K8s could kill and restart your container. This would interrupt the memory dump process.
Memory dumps could cause additional memory load on your container, hitting limits. Again, K8s could kill and restart your container. This would interrupt the memory dump process.
I was advised by Dynatrace to use an external ActiveGate(external to K8s). That works as intended, however I just find this whole setup a little weird due to quite a few of these interdependencies.
Can you please share how you setup this for Kubernetes environment? We have similar requirement of generating a heap dump for a process running on the container of kubernetes cluster.
I have reached out to our product team and confirmed that this is not supported but can be suggested as a future enhancement via a product idea. I have asked that one of my clients who have also inquired about having memory dumps for container ActiveGates file and product idea. As soon as it is posted I highly recommend voting for this feature to warrant testing and investigation from the Dynatrace product management team.
DId anyone ever get this working? i.e. Memory dump uploads for k8s?
We currently manually find the file on the nodes/containers, and move them somewhere e.g. S3 or download it directly.
