Good morning community.
I need to retrieve the metrics from the installed extension of an operating system, Windows Server 2003 Version 5.2 R2. The installed extension is MICROSOFT IIS.
However, it generates the following error: “Failed to assign monitoring configuration to ActiveGate. Reason: The monitoring configuration requires ActiveGate version 1.245.0 or later that supports data source WMI and belongs to group ‘default.’”
Hi @JohanZuleta ,
Yes, as you mentioned the OA doesn’t yet support Windows Server 2023 (EDIT : the OA no longer supports Windows 2003) (Technology support — Dynatrace Docs). I would need to defer to that team to know when that support would come.
However, as this extension is based on WMI, another option is to use an ActiveGate to remotely monitor IIS. Please take a look at this documentation (under Remote enable permission on the host) to see how to get that set up : WMI data source — Dynatrace Docs
I installed two extensions: Remote Windows Host Monitoring and Microsoft IIS. The first one works well for me, and I can already see infrastructure metrics with a local user on the host being monitored. However, under the Microsoft IIS extension, we encountered the following error:
Content: Failed to assign monitoring configuration to ActiveGate. Reason: GENERIC_ERROR: Status GENERIC_ERROR (27) returned from 1 agent (x.x.x.x: Cannot execute query: IIS Site on device x.x.x.x err: Exception occurred (invalid query)); Attached is the log for reference.
x.x.x.x belongs to the IP of the host being monitored.
If the queries produce an error on the host you are trying to monitor, the extension will not work either. Please provide the OS version of the host and the version of Internet Information Services Manager. Also, check in the IIS Manager that the sites are present on the host.
