Mobile application monitoring
Hi Team,
I’m using mobile app developed using React. Is that possible to get below listed metrics details specific to the mobile app in Dynatrace.
  1. Battery usage
  2. CPU utilization
  3. Memory utilization
  4. Low rendering speeds
  5. Network utilization
Hey,
Please clarify: You mentioned “React”, so I assume you mean you have a mobile application with React Native?
Yes. It is React Native
1 to 3 is not covered. 4 is covered in the way that you can monitor your Components. 5 is covered in the way that you can monitor web request from your application.
Thank you @matthias_hochri …
