Has anyone achieved configuration of OpenPipeline via Monaco?
OP has it’s own API endpoint but I haven’t seen any documented support for monaco for it?
It works with recent Monaco (2.15+), just the current API design for OpenPipeline is… not good. But improvements are in progress afaik.
Be sure to have Oauth client defined for monaco as stated here: Create an OAuth client for the Dynatrace Monaco CLI — Dynatrace Docs
Also check this https://docs.dynatrace.com/docs/shortlink/configuration-as-code-supported-configuration#platformapis for supported platform APIs.
Thanks Julius!
Strange that I didn’t find this documentation before. Assuming it is already there since monaco 2.15
